iec1088407 Thu, 12/27/2007 - 10:19
I usually use the MAC of the PC in where the IP Communicator is used, but also you can use a TAPI for emulate a MAC Address of a IP phone
peter_james712000 Fri, 12/28/2007 - 02:13
Hi Kartik,
Do you need info on how to get the MAC ID for a CIPC from a PC? or something else, Pls confirm
Kulasekararaja ... Sun, 05/06/2012 - 15:24
Hi Karthik,
If you want to user CIPC from your Laptop or from your Computer. First the MAC address of that either should be configured in Call manager.
To get the MAC address from your computer.  Start --> Run --> then type cmd it will open the below window
Then execute "getmac" which will retrive your MAC address of your local machine....
Note :- If it is laptop you may get 1. LAN MAC, 2. Wireless MAC, 3. VPN MAC as well
Kulasekara Raja. K
paolo bevilacqua Mon, 05/07/2012 - 00:03
  • Hall of Fame,
    Founding Member
Five years aged posts, unlikely the OP still needs an answer.
