How to find the patch levels installed in LMS 2.6
Dec 27th, 2007
The common services online help indicates that you can run: the "Applications and Versions Report" to obtain details about browser status and installed CiscoWorks packages, versions, installation dates, and installed patches. The procedure states:Select Server Configuration > About the Server > Applications and Versions. The Applications and Versions page is displayed.
The path it suggests does not exist in LMS 2.6 but seems to have existed in LMS 2.2. How can you run a report that identifies the application versions and patches applied.
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 12/27/2007 - 15:04
Go to Common Services > Software Center > Software Update, and click on the application name. All of the various subcomponent and patch versions can be seen on the resulting page.
