Warning message
ip address outside and ip address inside
Dec 27th, 2007
i am trying to setup a new pix firwall (525). i named the inside and the outside interfaces and set the security level on them , but when i try to assign an ip address for the inside and the outside the command fails, has anyone experienced this issue. any ideas, thanks.
johnd2310 Thu, 12/27/2007 - 12:58
  • Silver, 250 points or more
we will need more info. What error do you get when you try to configure ip address?
regards
John
Aidswailem Thu, 12/27/2007 - 14:37
the error i get is :
pixname(config)# ip address outside A.B.C.C 255.255.255.0
ERROR: % Invalid input detected at '^' marker.
the same error for inside or outside.
Also when i try to type ip address ? there is no outside or inside option from the ? mark.
johnd2310 Fri, 12/28/2007 - 02:34
hi,
what version of PIX os are you running? if you are running version 7.x or 8.x then you need to be in interface configuration i.e.
pixname(config-if)#
regards
John
