Tivo access through PIX
Dec 27th, 2007
I got a Tivo for Christmas and I'm trying to open the appropriate ports on my PIX 501 to allow it to communicate with the Tivo service. The Tivo knowlege base says I need to open these ports for inbound and outboud access:
- TCP 37,2190,4430, 7287-7288, 8000, 8080-8090
- UDP 123, 2190
I'm trying to set up an access list that only allows access over these ports to my Tivo box (internal IP 192.168.1.11) and prohibits access to other hosts on my inside interface over those same ports.
I tried to set up an access-list using the following config commands, but it's not working.
names
name 192.168.1.2 Neptune
name 192.168.1.11 Tivo01
access-list acl-in permit tcp any host Tivo01 eq 37
access-list acl-in permit tcp any host Tivo01 eq 2190
access-list acl-in permit tcp any host Tivo01 eq 4430
access-list acl-in permit tcp any host Tivo01 range 7287 7288
access-list acl-in permit tcp any host Tivo01 eq 8000
access-list acl-in permit tcp any host Tivo01 range 8080 8089
access-list acl-in permit udp any host Tivo01 eq ntp
access-list acl-in permit udp any host Tivo01 eq 2190
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group acl-in in interface outside
route outside 0.0.0.0 0.0.0.0 69.73.72.1 1
A debug trace when I attempt to connect from the tivo box to the tivo service includes the following suspicious entry:
710005: UDP request discarded from 192.168.1.11/2190 to inside:192.168.1.255/2190
Any thoughts on what's going on? A missing routing entry perhaps?? It almost looks like the Tivo's UDP request is getting broadcast to hosts on my internal LAN, but not getting routed outside??
BTW: Normal web traffic (inside clients hitting external web servers) works with no problems.
husycisco Thu, 12/27/2007 - 13:40
  • Gold, 750 points or more
Hi Christopher
I am assuming Tivo01 is not in outside interface so you cannot write ACLs as above. Also no translations (Static etc) exists
Is public IP going to be conneted for reaching Tivo01? Is Tivo01 in inside interface? Do you have another public IP then interface IP?
christopherfrancis Thu, 12/27/2007 - 14:06
The Tivo is on the Inside interface (192.168.1.x subnet). The Tivo's IP is 192.168.1.11. The PIX has a public external IP of 69.73.xx.xx. It's internal (gateway) address is 192.168.1.1.
I was expecting that the PIX would route outgoing requests from the Tivo to it's outside interface, but it appears to be dropping them. Not sure why. Similarly, I had expected the PIX to translaste/route responses from the Tivo server on the outside network to the correct internal (NAT'd) IP.
I suspect I've got a routing issue, but I'm not sure what I need to do to solve it.
cisco24x7 Thu, 12/27/2007 - 19:04
  • Silver, 250 points or more
Chris,
do this and it will work for you:
1- nat (inside) 1 0 0
2- global (outside) 1 interface
3- access-list test permit ip any any log
4- access-group test in interface inside
step 3 & 4 is optional but I put them in
there for testing.
cisco24x7 Thu, 12/27/2007 - 19:05
forget to add another step:
5- access-group test in interface outside.
this will make sure your firewall is
wide-open. Once you get it working, start
locking down the firewall.
christopherfrancis Sun, 12/30/2007 - 15:08
I'm sure it will work if I open everything up. What I'm trying to do is figure out how to make it work without doing that.
I think I've narrowed it down to an issue with ICMP. Apparently the Tivo box tries to Ping the Tivo server to verify connectivity before launching into the rest of its "conversation".
So I'm now trying to set up the PIX to allow the Tivo to Ping through the firewall, but am still running into problems.
Here's what my access list looks like now:
access-list acl-in permit icmp any host Tivo01 echo
access-list acl-in permit icmp any host Tivo01 echo-reply
cisco24x7 Sun, 12/30/2007 - 17:35
Do this:
logging enable
logging timestamp
logging buffer-size 1048576
logging buffered informational
logging trap informational
logging mail informational
access-list acl-in permit tcp any host Tivo01 eq 37 log
access-list acl-in permit tcp any host Tivo01 eq 2190 log
access-list acl-in permit tcp any host Tivo01 eq 4430 log
access-list acl-in permit tcp any host Tivo01 range 7287 7288 log
access-list acl-in permit tcp any host Tivo01 eq 8000 log
access-list acl-in permit tcp any host Tivo01 range 8080 8089 log
access-list acl-in permit udp any host Tivo01 eq ntp log
access-list acl-in permit udp any host Tivo01 eq 2190 log
access-list acl-in permit icmp any host Tivo01 echo log
access-list acl-in permit icmp any host Tivo01 echo-reply log
access-list acl-in deny ip any any log
After that, on the Pix, do the following:
CiscoPix# sh log | i Deny
This will tell you what is being dennied
on the outside interface. You will then
have to open additional port(s) for it to
work.
I would start from there.
CCIE Security
husycisco Mon, 12/31/2007 - 00:44
David,
Above ACLs have no use for allowing inbound connections. Tivo01 is a host in inside interface not outside.
Christopher,
For allowing outbound connection from Tivo, you need the following ACE in ACL which is grouped to your inside interface (if exists)
First, chek if you have an ACL grouped to inside interface
sh run access-group
If you see an xxxx (considering xxxx as your acl name if exists) as following
access-group xxxx in interface inside
then you need to add following
access-list xxxx permit tcp Tivo01 eq 37 any
access-list xxxx permit tcp Tivo01 eq 2190 any
Same for your other ports
And for inbound connection, which should be established to your outside interface in this case, you should first create statics as following
static (inside,outside) tcp interface 37 Tivo01 37 netmask 255.255.255.255
static (inside,outside) tcp interface 2190 Tivo01 2190 netmask 255.255.255.255
Same for other ports. (I suggest a dedicated public IP instead interface IP)
Then, allow the port traffic to interface as
access-list acl-in permit tcp any interface outside eq 37
access-list acl-in permit tcp any interface outside eq 2190
Keep in mind that, you dont have to allow inbound connection from a host in public, if the session is started from a host in your inside network.
If you still have problems, please post me your config.
