Setting up a 871W with a static IP
Dec 27th, 2007
Hi All,
I'm trying to setup a cisco 871W as a wireless router. It has an external IP, a gateway provided by our ISP, and two DNS servers. I can ping domains and IPs from within the router (via telnet), but I can't pint anything but the internal and external IP addresses of the 871W when connected through the WLAN or any fast ethernet port. I've tried to use SDM express and Cisco Configuration Assistant to get it working and can't seem to get it to pass any network traffic.
Here's my configuration. Any help would be greatly appreciated. This is my first cisco experience.
Using 3592 out of 131072 bytes
! Last configuration change at 16:55:53 PST Tue Dec 11 2007 by admin
! NVRAM config last updated at 16:56:00 PST Tue Dec 11 2007 by admin
version 12.4
no service pad
hostname CiscoWireless
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret xxx
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
resource policy
clock timezone PST -8
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.0.1
ip dhcp pool sdm-pool
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 216.x.x.254 216.140.17.254
lease 0 2
ip inspect log drop-pkt
ip domain name yourdomain.com
ip name-server 216.140.16.254
ip name-server 216.140.17.254
crypto pki trustpoint TP-self-signed-1700522519
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1700522519
revocation-check none
rsakeypair TP-self-signed-1700522519
crypto pki certificate chain TP-self-signed-1700522519
certificate self-signed 01 nvram:IOS-Self-Sig#3905.cer
username admin privilege 15 secret xxx
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$
ip address [external IP removed for privacy] 255.255.255.224
duplex auto
speed auto
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
ssid GuestNet
vlan 1
authentication open
authentication key-management wpa
wpa-psk ascii 0 885kqed9
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no snmp trap link-status
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
ip address 192.168.0.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 65.91.82.33
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner login (removed to save space)
line con 0
no modem enable
line aux 0
line vty 0 4
transport input telnet ssh
scheduler max-task-time 5000
end
Scott Fella Thu, 12/27/2007 - 17:42
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I believe that you need to confiugre NAT unless your ISP is going to issue dhcp to your clients.
gpetroski Sat, 12/29/2007 - 22:45
Hey man. You need the nat. do this:
config t
int fa4
ip nat outside
end
wr mem
config t
int BVI1
ip nat inside
end
wr mem
You should be good to go. Also, it looks you have no firewall and no IPS enabled on this device. Create some basic ACLs atleast to protect your self.Also, disable CDP on all interfaces. Use this
config t
int FA4
no cdp run
end
wr mem
Now it is all writen to the nvram startup-config and you are good to go. Here is the sample of my FA4
description TO_WAN_COMCAST$ES_WAN$$ETH-WAN$$FW_OUTSIDE$
ip address dhcp client-id FastEthernet4
ip access-group 105 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat outside
ip inspect SDM_MEDIUM out
ip ips sdm_ips_rule in
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no cdp enable
service-policy input sdmappfwp2p_SDM_MEDIUM
service-policy output sdmappfwp2p_SDM_MEDIUM
Access group 105 is actualy access list 105 applied inbound to the FA4 which is controling access to the router from the outside.
Here is the sample of 105 extended access list
access-list 105 permit udp host 68.87.77.130 eq domain any
access-list 105 permit udp host 68.87.72.130 eq domain any
access-list 105 permit udp host 4.2.2.1 eq domain any
access-list 105 permit udp host 131.107.1.10 eq ntp any eq ntp
access-list 105 permit udp host 209.81.9.7 eq ntp any eq ntp
access-list 105 deny ip 192.168.0.1 0.0.0.255 any
access-list 105 permit udp any eq bootps any eq bootpc
access-list 105 permit icmp any any echo-reply
access-list 105 permit icmp any any time-exceeded
access-list 105 permit icmp any any unreachable
access-list 105 deny ip 10.0.0.0 0.255.255.255 any
access-list 105 deny ip 172.16.0.0 0.15.255.255 any
access-list 105 deny ip 192.168.0.0 0.0.255.255 any
access-list 105 deny ip 127.0.0.0 0.255.255.255 any
access-list 105 deny ip host 255.255.255.255 any
access-list 105 deny ip any any log
In essence, you can substitute my DNS servers with yours (where it says eq domain) and then i have 2 time servers alowed in. you can omit this if not using NTP to synch your clock. Bootps and bootpc is for the DHCP to be able to dish out an IP for my FA4 interface from comcast. If you have a static IP from your ISP omit this. The line:
is very important and needs to be there so you dont block your own subnet. To implement the ACL do this
config t
then paste the text from the top.
exit
then config t
int fa4
end
wr mem
that should do it
Let me know if you have any more questions.
