SIP Phone unregistered, Communications Manager 6.0
Dec 27th, 2007
Hi, I am trying to use a Linksys WIP-330 SIP phone with communications Manager 6.0
After a little effort, I got everything to work, except I am having issues with the sometype of timer. After a certain amount of time approx 5 minutes the phone unregisters. If I turn the phone off then back on, it's fine for the same amount of time. I tried changing some timers even modifying the SIP profile, but nothing seams to make it work... Any help???
thanks
Overall Rating: 1 (1 ratings)
jfladouceur Wed, 01/02/2008 - 14:28
What does this have to do with the phone unregistering after 5 minutes of registering and being fully functional?
thanks
aessonel2008 Thu, 10/24/2013 - 05:48
Please, did you have any answer about the problem above? I'm facing the same issue right now and I need your help.
Thanks in advance for your support.
