GOLD Log
Dec 27th, 2007
Hi.
I have seen it GOLD logs on my C6K Switch
Dec 28 06:40:00 KST: %DIAG-SP-STDBY-6-SCHED_RUNNING: Module 8: Performing Scheduled Online Diagnostic...
Dec 28 06:40:00 KST: %DIAG-SP-STDBY-6-TEST_RUNNING: Module 8: Running TestFabricSnakeForward{ID=24} ...
Dec 28 06:40:01 KST: %DIAG-SP-STDBY-6-TEST_OK: Module 8: TestFabricSnakeForward{ID=24} has completed successfully
Dec 28 06:40:01 KST: %DIAG-SP-STDBY-6-TEST_RUNNING: Module 8: Running TestFabricSnakeBackward{ID=25} ...
Dec 28 06:40:02 KST: %DIAG-SP-STDBY-6-TEST_OK: Module 8: TestFabricSnakeBackward{ID=25} has completed successfully
Dec 28 06:40:02 KST: %DIAG-SP-STDBY-6-SCHED_COMPLETE: Module 8: Scheduled Online Diagnostic is completed
Dec 28 06:40:02 KST: SP-STDBY: Online_lc_ctrl_api: lc_ctrl_send_pak: Unknown slotid 0
What's that mean Line 7 log ? (SP-STDBY: Online_lc_ctrl_api: lc_ctrl_send_pak: Unknown slotid 0)
Thanks for your help.
aghaznavi Thu, 01/03/2008 - 11:22
  • Silver, 250 points or more
SUBFACILITY is used only for Cisco Catalyst 6000 series switches that are operating in a distributed system. The subfacility can consist of one code, or two codes that are divided by a hyphen, and describes the part of the distributed system from where the message is coming. For example, the %DIAG-SP-STDBY-6-RUN_MINIMUM system message is the %DIAG-6-RUN_MINIMUM message coming from the switch processor (SP) that is in redundant or standby (STDBY) mode
