NAT working 1 way but not the other?
Dec 27th, 2007
Hey guys.
I have an ASA with an outside/inside/DMZ scenario. (TMP-WAN is the DMZ)
I've got the global statements working on both the inside and outside interfaces. PAT on the outside works fine. PAT is also on the inside interface as there are a number of other networks that go through the inside interface (another router on the inside lan nwith networks behind it) That also works fine.
I have added static NAT statements for the TMP-WAN interface, i can reach every network out that interface, but not the other way around. I get Deny TCP no connection inbound on TMP-WAN errors. I also get TCP reset-O errors immediately back. Here is the config (attached)
Any insight would be greatly appreciated. I've tried adding another static NAT rule reversing inside and TMP-WAN but to no avail. thinking there was no translation rule coming back in, but it didn't seem to work or i didn't get the syntax correct. Any help would be great..
I'm not sure if you need all networks on INSIDE and TMP-WAN to communicate but go ahead and edit this as needed.
no static (TMP-WAN,inside) 10.216.32.0 10.216.32.0 netmask 255.255.255.0
object-group network TMP-WAN
network-object 10.216.24.0 255.255.255.0
network-object 10.216.28.0 255.255.255.0
network-object 10.216.32.0 255.255.255.0
network-object 10.224.0.0 255.248.0.0
network-object 10.216.2.0 255.255.255.252
object-group network INSIDE
network-object 10.216.132.0 255.255.255.0
network-object 10.216.136.0 255.255.255.0
network-object 10.216.140.0 255.255.255.0
network-object 10.216.20.0 255.255.255.0
network-object 10.216.16.0 255.255.255.0
network-object 10.216.14.0 255.255.255.0
network-object 10.216.1.0 255.255.255.0
network-object 10.216.69.0 255.255.255.0
network-object 10.216.10.0 255.255.255.0
access-list INSIDE-TO-TMP-WAN permit ip object-group INSIDE object-group TMP-WAN
nat (inside) 0 access-list INSIDE-TO-TMP-WAN
access-list TMP-WAN_nat0_outbound permit ip object-group TMP-WAN object-group INSIDE
clear xlate
bob.bartlett Sat, 12/29/2007 - 08:14
One thing to add you can clean up your config by doing dynamic routing either ospf or eigrp with the inside router and the ASA.
