Cannot assign route-map to vlan interface on 3750
Dec 27th, 2007
Version 12.2(25)SEE4
IPSERVICES
access-list 100 permit ip 10.23.10.0 0.0.0.255 any
route-map rm permit 10
match ip address 100
set ip next-hop 10.23.7.1
c3750-01-core#conf term
Enter configuration commands, one per line. End with CNTL/Z.
c3750-01-core(config)#int vlan14
c3750-01-core(config-if)#ip policy route-map rm
c3750-01-core(config-if)#^Z
c3750-01-core#sho run int vlan14
Building configuration...
Current configuration : 239 bytes
interface Vlan14
ip address 10.23.11.1 255.255.255.0 secondary
ip address 10.23.12.1 255.255.255.0 secondary
ip address 10.23.10.1 255.255.255.0
end
WTF??? where is route-map?
Overall Rating: 5 (1 ratings)
royalblues Thu, 12/27/2007 - 23:59
What is the SDM template you are running on the switch? By default the switch runs desktop default template which can be verified using " SH SDM PREFER"
You would require an SDM routing template for PBR support. You would require a reboot to take the new setting into effect
http://www.ciscosystems.cd/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00808c73cc.html
Narayan
ctalaski Wed, 01/02/2008 - 08:25
I've had similar experiences and contacted Cisco to ask about this... I was informed that I would need to upgrade my IOS to "Advanced IP SERVICES" version in order to get this feature.
