Dec 28th, 2007
Dear Experts ,
I've found one document in which SNMP is used to to copy a configuration file to and from a Cisco device with the CISCO-CONFIG-COPY-MIB.
It is not supported on Catalyst switches.
Anybody has any idea how to the same on Catalyst switches.(i.e 3750 switch).
Enclosed is the url for your reference.
David Stanford Fri, 12/28/2007 - 06:30
This MIB is supported on the 3750, so it should work. It doesn't not work on Catalysts running CatOS.
