Correct Answer
Danilo Dy Fri, 12/28/2007 - 02:27
  • Blue, 1500 points or more
Try "show diagnostics"
Dandy
shrikar.dange Fri, 12/28/2007 - 02:36
  • Bronze, 100 points or more
you can use the sh tech command
but you need to do some work to find it out do capture the output of command before firing!!!!
regards,
shri
slaptijack Sun, 01/27/2008 - 00:06
I'm not sure which version of IOS this started in, but newer versions accept a 'page' parameter to cause the output to page rather than scroll continuously.
show tech-support page
