spanning-tree portfast bpduguard default
Answered Question
Dec 28th, 2007
Hi NetPro,
just have a quick check , with this command will only apply to Access switch only ? or deploy to Core-switches , Distribution switches ?
your reply will be highly appreciated.
thanks.
regards,
Jackal
Correct Answer by royalblues about 9 years 4 months ago
The command is configurable on any switch but in practice will be genrally configured on the access switches.
The Core/distribution switches would mostly carry only trunk uplinks or L3 routed ports and hence it is not configured
Narayan
Correct Answer by Fraser Reid about 9 years 4 months ago
Quick guess - access ports only.....
Overall Rating: 4.7 (3 ratings)
Correct Answer
royalblues Fri, 12/28/2007 - 06:27
  • Green, 3000 points or more
Narayan
bvsnarayana03 Fri, 12/28/2007 - 06:48
  • Silver, 250 points or more
Portfast is generally enabled on all ports to which the enduser desktops are connected.
Access switches are generally meant for that. So mainly on access switches or any desktop connected ports.
