Digital Voice Gateway CCM Licensing
scheikhnajib
Hi All,
I'm designing a voice solution but got stuck on some CCM licensing issues.
I need to connect a branch office PBX to a Cisco 2811 router with NM-HDV2-1T1/E1 and this router will then talk to a central CCM cluster. This branch office has 100 users using analogue phones conencted to the PBX.
What is the CCM license required for this setup? Is it a single H.323 gateway license? Is it a license per user?
If you can provide the required part numbers it would be great.
S.
Rajesh Revuru
Level 4
Level 4
Are you going to use any call manager express or CUE on 2811? If not, i dont think you would need any other licensing.
What version of CCM are you using at the main site?
No CCME on 2811. CCM 6.0 in central site.
S.
So i think you are fine, see the following document regarding licensing. You would only need DLU if you are adding end-points.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item0900aecd805009fc.shtml
