Monitoring traffic going through a router as troubleshooting tool..
Dec 28th, 2007
Hello All, I would like to monitor traffic traversing a router, in the same manner that I can see connections on a Pix firewall with "show connection" command.
Is it possible on cisco routers?
Overall Rating: 4 (2 ratings)
glen.grant Fri, 12/28/2007 - 10:47
Not being that familiar with pix's what does that command tell you for information ?
Collin Clark Fri, 12/28/2007 - 10:48
If the router is running NAT than you can use "show ip nat translations". You could also use NBAR and/or netflow to monitor traffic ports and protocols.
HTH and please rate.
