WLC failover
Dec 28th, 2007
I am trying to configure the primary and secondary controllers name in order the have AP failover. I have assigned the intial controller IP with DHCP, then if convert the AP to a static addess and configure a different conroller on AP detail page and then reset the AP it will still connect to the same controller.
When I look at the APs config I see the origianl controller is listed as Configured Switch 1 Addr the controller I set as primary controller name is set as mwarName. It seems as something is not working correctly.
dancampb Sat, 12/29/2007 - 09:02
  • Cisco Employee,
For AP's to failover to another controller you need to make sure that AP fallback is enabled on the controller and also make sure the controllers are in the same mobility group.
koksm Mon, 01/14/2008 - 04:42
Please correct me if i am wrong, but as far as i know AP fallback is used to tell the AP to switch back to the primary controller after failover, when his configured primary comes back online again?
Scott Fella Tue, 01/15/2008 - 14:27
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You are correct, but you need to configure the WLC's in the mobility group in order for AP Failover. Once an ap first joins a WLC it keeps the ip of the controller and the info set in the mobility group. The secondary WLC info is kept in the mobility group in which you have not configured so the AP only knows of the controller it first joined.
koksm Wed, 01/16/2008 - 22:56
Ofcouse, the mobility group is mandantory for AP failover to work.
But AP fallback is something else...
Scott Fella Thu, 01/17/2008 - 08:20
  • Hall of Fame,
    2017 Wireless
Your AP's are on a different vlan than the controllers and that is why your ap is joining the original WLC.
You have to cofigure ip-helper pointing to both the management ip address of your WLC. Of course you know this has to be configured on the L3 interface your AP's are on. You also have to configure globally ip forward-protocol udp 12222 a 12223.
Now as long as AP fallback is configured, your ap will join its primary WLC configured.
Hope this helps.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
