12-28-2007 03:19 PM - edited 07-03-2021 03:09 PM
why is 871w so hard to configure out of hte box? i used tech republic, and its no good
12-28-2007 03:20 PM
anyways, is there a link as how to configure this bad boy? i have a cable modem. currenlty using D-Link. i have wiped hte config clean on the 871w
01-02-2008 07:59 PM
So depending if you're more comfortable with CLI or GUI, the below links can get you going.
CLI
If you're not familiar with CLI give Security Device Manager (SDM) a try.
SDM Quick Start
Basic Router Config
Authentication types
Later...
