MSS-exceed
Dec 28th, 2007
ASA 5510 with a switch in the DMZ that we are trying to access the web interface over https. the connection fails and logs the error syslogid419001 Dropping TCP packet from dmz:smswitch.internal/80 to outside:cox.home/50206, reason: MSS exceeded, MSS 1260, data 1430
the firewall is running 8.03
phil.davenport Mon, 12/31/2007 - 15:54
Your client tcp maximum segment size (MSS) is set to 1260 however the switch webserver is ignoring the MSS sent by the client and sending back data exceeding the TCP MSS. v7.0 onwards default behavior is to drop this packet to defend against buffer overrun. Below document should help you. If the webserver is running on a Cisco switch maybe worth raising a TAC case once you've looked through the doc.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804c8b9f.shtml
whanson Wed, 01/09/2008 - 16:02
this will fix your problem. It is set for outside interface, but you can alter for dmz
access-list mssexceed extend permit tcp any any
class-map mssexceed-map
match access-list mssexceed
policy-map mss-exceed-policy
class mssexceed-map
set connection advanced-options mss-map
tcp-map mss-map
exceed-mss allow
service-policy mss-exceed-policy interface outside
phillipediab Thu, 04/17/2008 - 13:58
from my experience, applying it on the outside interface didn't take effect. I have to apply it in a global policy and still the tcp mss exceeds kept showing up. we had to reload the ASA for the global policy to take effect
phillipediab Thu, 04/17/2008 - 13:59
opers13 Mon, 05/19/2008 - 14:20
a reload is really necessary..? Anyone else done this?
