errors on multilink
Dec 28th, 2007
I have configured a multilink (1 serial E1 links bundled to a single link) and after that i am facing some packet drops on that multinilk. During investigation i found some errors on multilink
sh ppp multilink
Multilink2, bundle name is XXXX_Secondary
Bundle up for 3w6d
407491 lost fragments, 259087128 reordered, 0 unassigned
494274 discarded, 439343 lost received, 28/255 load
0xC50A00 received sequence, 0x25DB3B sent sequence
Member links: 3 active, 0 inactive (max not set, min not set)
Serial4/0/0, since 3w6d, last rcvd seq C50A03
Serial5/1/3, since 3w6d, last rcvd seq C50A04
Serial4/0/3, since 1d14h, last rcvd seq C50A02
See these lines
My multilink configuration follows
interface Multilink1
description ***** Connected to Dhondusa*****
ip address x.x.x.x 255.255.255.252
ip ospf cost 16
no cdp enable
ppp multilink
ppp multilink fragment-delay 20
ppp multilink interleave
multilink-group 1
I read somewhere that multilink interleaving is necessary only on low bandwidth links , so i removed
the above two commands from my configuration. But still... i am getting the same errors. I made sure that none of my physical interfaces shows any errors or reliability isses..Can anyone pls help me to overcome this?
Thanks in Advance
Sony
paolo bevilacqua Sat, 12/29/2007 - 05:29
  • Hall of Fame,
    Founding Member
Hi, can you send "show interface" and "show controller" for the three links comprising the bundle, taken on both routers.
