Web access to switch in DMZ issue
Dec 28th, 2007
when we try to connect to the web interface we get this in the logs Dropping TCP packet from dmz:smswitch.internal/80 to outside:cox.home/50206, reason: MSS exceeded, MSS 1260, data 1430
JORGE RODRIGUEZ Sat, 12/29/2007 - 10:10
Robert, did you follow the example in the link using service-policy to activate the policy map created and apply it on outside interface? and using the keyword exceed-mss allow ?
I did some other search and found this is the only way to make this work even on version 8.0 as this is only done through policy framework class-map etc..
also on your original post you indicated this only happens on only a particular weblink , lookin at the log cox.home ? do you know the actual link dns name?
JORGE RODRIGUEZ Sat, 12/29/2007 - 11:32
try this script and add it to your global policy, replace server_ip with the destination dmz host ip address.
access-list http-list permit tcp any host server_ip eq 80
class-map http
match access-list http-list
tcp-map tmap
exceed-mss allow
policy-map global_policy
class http
set connection advanced-options tmap
bob.bartlett Sat, 12/29/2007 - 16:09
I did that previously and it didn't work. As for the DNS it is a switch and the switch does not have a dns entry. We access it by IP.
