Spaning-tree | Trunk
Dec 29th, 2007
Hi netpro,
when i type " show int trunk " i got this result. this is something wrong .
Port Vlans in spanning tree forwarding state and not pruned
Gi1/1 none
Gi2/1 1,10-11,20,22,30,40,50-51,60-61,70-71,80-84,90-94,100-102,110-113,120,130,140-142,144,150-155,188-189,192-195,198-200,210,220,225,301-302,311,400-402,405
Fa4/46 210,220,225
Fa4/48 210,220,225
Fa5/48 210,220,225
Port Name Status Vlan Duplex Speed Type
Gi1/1 connected trunk full 1000 1000BaseSX
your reply will be highly appreciated.
thanks.
regards,
jackal
Overall Rating: 4 (1 ratings)
glen.grant Sat, 12/29/2007 - 12:22
Please reply why you think something is wrong ... G1/1 may not have anything in the forwarding statement if there is an alternate path to the same device . Do a show spanning-tree blockedports " and see if everything is blocked across that link .
ney25 Sat, 12/29/2007 - 23:24
Hi Glen,
thanks for reply, the reason i said that was because, i have enable the pruning and spanning-tree root brigde 8192 and 16382.
so, when i show int trunk . it should be gi1/1 - 1,3,5,7,9 ...etc
gi1/2 - 2,4,6,8,10 ...etc
thanks.
regards,
Jackal
Jon Marshall Sun, 12/30/2007 - 11:07
Hi Jackal
If you have VTP pruning enabled it doesn't matter which switch you set as root or secondary, what matters is which ports are in which vlans on the switch at the other end of the trunk link ie.
gi1/1 connects to a switch. Does this switch have any ports that have been allocated to vlan 1,3,5,7,9 etc... If not then the trunk will show "none" as in your output above. Remember that the first line of output says
So if you have no ports allocated to any of the vlans on the switch connected to gi1/1 it will prune those vlans from the trunk.
As a test go onto switch connected to gi1/1 and allocate a port into one of your vlans.
Jon
ney25 Mon, 12/31/2007 - 03:23
Hi Jon,
thanks for reply, i got it.
thanks.
regards,
Jackal
