Router 1841 clock rate
Dec 29th, 2007
Hi frds
I have a freash router 1841 at its serial interface i configured for E1 link but it atumaticlly shows clock rate of 2000000 this . I tried to remove it i am unable even i have change its IOS and erase the NVRAM and reconfigurd it
but always it shows clock rate 2000000
,but i can change the rate but unable to ' No clock rate 'can anyone help me to remove clock rate
Overall Rating: 4 (2 ratings)
Paolo Bevilacqua Sat, 12/29/2007 - 04:23
  • Hall of Fame,
    Founding Member
Which interface is that ? Which cable is attached? Show diag and show controller to know that.
Paolo Bevilacqua Sun, 12/30/2007 - 09:09
  • Hall of Fame,
    Founding Member
Hi, you should send the full out of the commands requested for us to check on things.
However, if the attached cable is DTE, the only possible reason is a software bug.
jagdev.dhaliwal Sun, 12/30/2007 - 22:51
Hi Sir , I have already upgrade the IOS but it is still there however commands are
interface Serial0/0/0
description ## Link from FRIENDS GGN - D184 Okhla ##
bandwidth 1984
ip address 10.254.0.66 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
clock rate 2000000
no cdp enable
ohassairi Sun, 12/30/2007 - 10:30
  • Silver, 250 points or more
i have the same problem. but once the serial interface plugged to a modem this command will disappear and it functions fine.
andychua.chua Sun, 01/20/2008 - 22:15
if you are not using the serial interface then it wont do anything. if you are using the serial interface, and are acting as the DCE (pretty sure its DCE and not DTE) then you must use clockrate command. It is used when you are providing clocking on a serial interface to link up a connection. Normally, the router will determine if you are using a DCE or DTE connection and use the clockrate if it is needed. if there is no connection, then the default is to show the clockrate command, I believe.
basically, if you are not using the interface, then it doesnt hurt to leave it in. if you are using the interface, then it needs to be set to the right value.
