remote access vpn
Dec 29th, 2007
when i am trying to connect remotely from different laptops to pix, using vpn client software, able to get connections for all clients and the clients are getting different ip addresses from the pool mentioned in the pix configuration. But, all clients are getting the same mac address. is there any solution for this issue, so that the remote clients get different mac addresses like they are getting different ip addresses
ccbootcamp Tue, 01/01/2008 - 21:06
  • Gold, 750 points or more
What do you mean your clients are getting the same MAC address?!?!?! The MAC address should be set on your PC, not dished out by the PIX.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
maktala007 Wed, 02/06/2008 - 10:43
I mean when i run "ipconfig /all" on the systems which are connected through the remote access vpn, they displaying e.g.
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Cisco Systems VPN Adapter
Physical Address. . . . . . . . . : 00-05-9A-3C-78-00
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.168.10
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
All systems are getting different ip addresses but same physical address.
