CUE parameter MaxRetry
Dec 29th, 2007
CUE ver. 3.0.1
I wrote my own script
I want to set parameter MaxRetry = 0
Or
I want to change "Are You Still There" prompt to my language.
CUE outputs following
se-10-1-10-1(config)# ccn application autoattendant aa
Modifying existing application
se-10-1-10-1(config-application)# description "autoattendant"
se-10-1-10-1(config-application)# enabled
se-10-1-10-1(config-application)# maxsessions 8
se-10-1-10-1(config-application)# script "grupofis.aef"
se-10-1-10-1(config-application)# parameter "MaxRetry" "0"
no such attribute
Markus Schneider Sat, 12/29/2007 - 18:49
  • Cisco Employee,
I'd try entering the parameter without the quotes (in the parameter or the value, e.g. parameter MaxRetry 0
Otherwise, I assume that MaxRetry (with the same upper/lower case letters) exists in the grupofix.aef script and the Parameter checkbox is checked on the variable. When in doubt, Just log into the CUE GUI and set the parameter there.
rsefer Sun, 12/30/2007 - 00:39
Thank you,
How can I change "Are You Still There" prompt to my language? in aa.aef
Paolo Bevilacqua Sun, 12/30/2007 - 05:24
  • Hall of Fame,
    Founding Member
For which language have you installed CUE ?
If the correct one, all prompts should have been translated. It is not the case for you ?
rsefer Sun, 12/30/2007 - 07:56
in TURKISH
in fact I want to remove it completely
How can I disable it in aa.aef?
I set MaxRetry=0
This doesnt work
THANKS
Paolo Bevilacqua Sun, 12/30/2007 - 08:06
  • Hall of Fame,
    Founding Member
Hi, since Turkish doesn't appear to be a supported language, I guess your only choice is to see if changing or making a parameter of the "Timeout Prompt" variable can help.
