IAD2431 Load IOS
Dec 29th, 2007
I have an IAD2431 that the IOS has been deleted off of and I am trying to load via the Compact Flash but I keep getting errors and it will nto load. Any ideas on best way to load the IOS from ROMMON?
ccbootcamp Sat, 12/29/2007 - 10:20
  • Gold, 750 points or more
What kind of errors are you getting from the CF? I suppose you could always do an XMODEM from ROMMON (assuming that's available on the IAD).
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
paolo bevilacqua Sat, 12/29/2007 - 10:21
  • Hall of Fame,
    Founding Member
Type "tftpload" in rommon. It will tell you which parameters you have to set to load the image. To set a parameter, just type it followed by = and the value. Then connect the TFTP server to the lowest LAN and repeat the command, tftpload.
nshoe18 Sat, 12/29/2007 - 10:26
I am getting errors stating that the c2400-atafslib-m not found. I do not have an IP on the IAD so I do not think I can TFTP the IOS to it. I am trying to do it via XMODEM which of course is about a 4 1/2 hour process
paolo bevilacqua Sat, 12/29/2007 - 11:01
  • Hall of Fame,
    Founding Member
Exactly because of length via xmodem, TFTP is provided. The IP is given at the time you config as mentioned above.
paolo bevilacqua Sat, 12/29/2007 - 11:08
  • Hall of Fame,
    Founding Member
I don't seen rommon prompt or tftpdnld command in the file included. When turning on the router, send one or two breaks from the terminal program, and this will give you rommon.
