Does CCIE Meet CCDA Requirements
Dec 29th, 2007
One of the requirements of a CCDP is a CCDA. Does a valid CCIE meet the CCDA requirement? The certification progress page seems to suggest that but I'm not sure.
Jesse
srue Sat, 12/29/2007 - 10:33
the requirements for a CCIE are really independent of the requirements from either the associate or professional level certs.
Yes, to get your CCDP, you must also have a valid CCDA. A valid CCIE doesn't meet the CCDA requirement.
ccbootcamp Sat, 12/29/2007 - 10:49
No, it doesn't. What you are probably reading into, is that the CCIE written is a possible choice as a re-cert path for the CCDA. Does this make sense?
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
