IPCC Express CTI ports cycling
Dec 29th, 2007
  • Bronze, 100 points or more
I am trying to configure 2nd CRS script that just plays simple prompt. The prompt is the same as in 1st script so I know prompt is good.
I have created a new Trigger/Application/CTI RP and so forth. All Subsystems appear OK. Saved Script, reloaded App, restarted Engine. When I dial new CTI RP I see it connects to the first available CTI port. Then I hear a beep and I see it is trying next CTI port and then beep again and next CTI port and so on.
What am I missing? CRS 3.5.4
Thanks.
Chris Deren Sat, 12/29/2007 - 15:37
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Do you have an application pointing to this script configured in IPCCX?
Is there a trigger associated with this app?
Is there a CTI Group and media group associated with this trigger?
Can you post your script?
Chris
yshraybman Sun, 12/30/2007 - 16:29
Well, I got it working. I simply copied working script and made it the same as non-working script. Go figure why it did not work in the begining.
