Best Cisco for the Job
Dec 30th, 2007
For one of our offices we have a cable modem & DSL
Currently I am using a Cisco 831 but I need a router with 2 WAN interfaces
I have been looking into a 1721 & 1841
Any cost effective Recommendations?
Overall Rating: 3 (1 ratings)
paolo bevilacqua Sun, 12/30/2007 - 05:40
  • Hall of Fame,
    Founding Member
The 1721 is not being made anymore. If you are willing to buy an used unit, then you can also look for 1750, 2600XM, etc.
On the other hand, the 1841 is the smaller modular router, allowing multiple WAN interface, being currently manufactured by cisco.
