CCM 5.1 and fxo direct lines
Dec 30th, 2007
i have cisco call manager connected to the gateway 2851 that contains 28 fxo.
Some of ip phones must have inboud and outbound calls but via one direct line.
how can i configure it in the CCM and voice gateway ??
thanks at advance.
paolo bevilacqua Sun, 12/30/2007 - 08:59
  • Hall of Fame,
    Founding Member
Do you use H.323 or MGCP to the GW ?
paolo bevilacqua Sun, 12/30/2007 - 09:14
  • Hall of Fame,
    Founding Member
For incoming, configure "connection plar XXX opx" where XXX is the extension where you want the call to be sent.
For outgoing, follow the configuration detailed at:
http://cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
dbenattou Sun, 12/30/2007 - 09:33
thanks a lot for your help.
i will test it tomorrow and i will answer you
Thanks again.
