what is wrong with this router?
Dec 30th, 2007
The following lab router provides error messages. Could someone assist with troubleshooting.
Thanks.
Destination filename [startup-config]?
Building configuration...
[OK]
Router#ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Unexpected exception to CPUvector 1100, PC = 0
-Traceback=
Free space check for flash:crashinfo_19930301-000303 failed (212/4219)
=== Flushing messages (00:03:03 UTC Mon Mar 1 1993) ===
Queued messages:
*** System received a SegV exception ***
signal= 0xb, code= 0x1100, context= 0x8153d2d8
PC = 0x0, Vector = 0x1100, SP = 0x80005f4c
System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
C2600 platform with 65536 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x79d370
Self decompressing the image : #################################################
[OK]
Smart Init is disabled. IOMEM set to: 25
Using iomem percentage: 25
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Overall Rating: 5 (1 ratings)
Hi, your line card buffers are full and can't handle anymore messages. try the Cisco solution posted below. HTH
1. %GRP-3-IFCON: Too many Queued messages, No buffers available
Too many messages are coming from the Internet router line card. There are no more buffers on the RP to handle these messages.
Recommended Action: Try shutting down debugging messages on the line card or reloading it. Copy the error message exactly as it appears on the console or in the system log, contact your Cisco technical support representative, and provide the representative with the gathered information.
Related documents-
Cross-Platform Release Notes for Cisco IOS Release 12.0 S, Part 6: Caveats for 12.0(6)S through 12.0(23)S6 [Cisco IOS Software Releases 12.0 S]
Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://www.cisco.com/cgi-bin/front.x/case_tools/caseOpen.pl, or contact your Cisco technical support representative and provide the representative with the information you have gathered. Attach the following information to your case in nonzipped, plain-text (.txt) format: the output of the show logging and show tech-support commands and your pertinent troubleshooting logs.
Related documents- No specific documents apply to this error message.
