Need solution
Dec 31st, 2007
Kindly provde me solution how can i implement the bellow.We are using IDS-4235 v 4.1..
Update: In addition to the domains mentioned above, more malicious domains
are being reported. The comple list of malicious domains is as follows:
uhave post card DOT com
merrychristmasdude DOT com
americangreetings DOT b719 DOT cn
americangreetings DOT 846123 DOT cn
lbss DOT 3322 DOT org
happycards2008 DOT com
newyear2008 DOT com
newyearcards2008 DOT com
newyearwithlove DOT com
Note: Users are advised to visit this page regularly to get the updated
list of malicious domains.
Users are advised to implement following countermeasures:
It has been observed that the malicious domains such as mentioned above are
hosted by the Storm Botnet mostly using nginx/0.5.17 web server . Consider
blocking packets from the nginx/0.5.17 web server through Proxy or set an
appropriate alert/rule at IDS/IPS
wsulym Mon, 12/31/2007 - 07:20
you can use the string.tcp engine, with the following regex:
*from* #WEBPORTS
to detect the nginx webserver.
You can also use string.udp (setting *to* port 53) to trigger alerts on dns requests for the domains mentioned. For the dns regex, you need to be aware that the query will take the form of:
length-byte -- characters -- length-byte -- characters
So something like 2 characters, 6 characters, then 3 characters. Gets strung together as such:
That is the regex to catch regardless of case in a dns query (UDP).
(note that the dots in the name, do not appear in the regex string)
