WLC firmware downgrade
Answered Question
Dec 31st, 2007
Does anybody know if it is possible to downgrade a WLC by dowloading a lower version of the code ?
Or does this depend on the versions ?
Gerard van Bon
Correct Answer by Rob Huffman about 9 years 5 months ago
Hi Gerard,
You can Downgrade the WLC Release Version, but be careful of this note;
Caution: If you require a downgrade from one release to another, you may lose the configuration from your current release. The workaround is to reload the previous controller configuration files saved on the backup server or to reconfigure the controller.
Managing Controller Software and Configurations
http://www.cisco.com/en/US/docs/wireless/controller/4.1/configuration/guide/c41mfw.html
The only rstriction I have seen to downgrading is with some of the Mesh Releases. You can see the details here;
Cisco 4400 Series Wireless LAN Controllers Release Notes
http://www.cisco.com/en/US/products/ps6366/prod_release_notes_list.html
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Mon, 12/31/2007 - 09:18
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Gerard,
Hope this helps!
Rob
vanbon Tue, 01/01/2008 - 00:20
Thanks Rob,
This helps al lot.
Kind regards,
Gerard
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
