Input and Abort errors on PA-POS-2OC3
Dec 31st, 2007
  • Bronze, 100 points or more
It's on a point to point circuit, with 14 frame relay sub interfaces in bridge groups to carry VLAN traffic from one office to the other across town. One router is configured to act as the frame relay switch, and the one having the trouble it the other router. Circuit has been tested several times, and pronounced OK. PA-POS-2OC3 card has been replaced too. One thing we did note is if the sub interface carrying the majority of the traffic is disabled, the errors cease. We monitored it for half an hour with no errors, any ideas on this one?
POS1/0 unassigned YES NVRAM up up
POS1/0.1 172.XXXXX
YES NVRAM up up
POS1/0.128 unassigned YES unset up up
POS1/0.140 unassigned YES unset up up
POS1/0.601 unassigned YES unset up up
POS1/0.602 unassigned YES unset up up
POS1/0.603 unassigned YES unset up up
POS1/0.604 unassigned YES unset up up
POS1/0.605 unassigned YES unset up up
POS1/0.606 unassigned YES unset up up
POS1/0.607 unassigned YES unset up up
POS1/0.608 unassigned YES unset up up
POS1/0.609 unassigned YES unset up up
POS1/0.610 unassigned YES unset up up
POS1/0.611 unassigned YES unset up up
POS1/0.700 unassigned YES unset up up
POS1/0 is up, line protocol is up
Hardware is Packet over Sonet
Description: P2P OC-3 to bossecnj06 -- AGEC.885577..ATI -- 32OBGS154484 NY
MTU 4470 bytes, BW 155000 Kbit, DLY 100 usec,
reliability 255/255, txload 10/255, rxload 215/255
Encapsulation FRAME-RELAY, crc 32, loopback not set
Keepalive set (10 sec)
Scramble disabled
LMI enq sent 2258, LMI stat recvd 2230, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 1023 LMI type is CISCO frame relay DTE
FR SVC disabled, LAPF state down
Broadcast queue 0/256, broadcasts sent/dropped 157944/0, interface broadcasts 188335
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 06:16:19
Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/4096 (size/max)
30 second input rate 130929000 bits/sec, 11325 packets/sec
30 second output rate 6646000 bits/sec, 6450 packets/sec
245668143 packets input, 1035969915 bytes, 0 no buffer
Received 111838 broadcasts, 169045 runts, 0 giants, 0 throttles
0 parity
340654 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 192678 abort
139117498 packets output, 2089965604 bytes, 0 underruns
0 output errors, 0 applique, 0 interface resets
0 carrier transitions
