12-31-2007 06:12 AM - edited 03-05-2019 08:13 PM
This is a very strange problem that I have. We have a site in which is connected to two other sites via BT Les 100 lines (dark fibre effectively). Last week the switches in one site just stopped any spanned vlan's working across the data links.
The links are still operational and all layer 3 trafic is running as normal - we just haven't got any layer 2 traffic.
Nothing was changed on the switches (in fact there weren't any network engineers on site) or the routers but the spanned vlans just stopped. rebooting the switches didn't make any difference either.
The switches are 3750 stack units running ios 12.1(19) which I know is out of date but they have been running quietly for the last 3 years without a problem.
Any suggestions - I am going to replace them with a 4507 in the next week or so anyway but was just curious as to the fault.
Giles
12-31-2007 11:15 AM
Are the inter-switch links configured as trunk or access switchports ?
Can we see the portion of the config from either end ?
01-02-2008 02:09 AM
Network Configuration from "working" end
interface FastEthernet3/19
description LES100 to TRE-SWST1 Fa1/0/48
switchport trunk allowed vlan 1-3,5-7,9,600,634
switchport mode trunk
speed 100
duplex full
qos trust dscp
auto qos voip trust
tx-queue 3
bandwidth percent 10
priority high
shape percent 30
service-policy output autoqos-voip-policy
end
Networ Configuration from "faulty" end.
interface FastEthernet1/0/48
description *** Trunk to BRE-IerE3-CORE01 Fa3/19 (LES100) ***
switchport trunk allowed vlan 1-3,5-7,9,634
no ip address
duplex full
speed 100
srr-queue bandwidth share 10 10 60 20
priority-queue out
mls qos trust dscp
no mdix auto
end
Both ends of the link are still operational for routing just not for trunk links.
As you can see both ends are configured as trunk links running the same encapsulation.
The strange thing is that the link just failed after 3 years of normal operation.
Giles
01-13-2008 03:29 AM
Update on this problem.
Last night we swapped the "faulty" switch for the new 4500 I had previously prepared. We still have the same problem with layer 2 traffic not traversing the links.
the new configuration from the core is as follows:
interface GigabitEthernet3/19
speed 100
duplex full
qos trust cos
tx-queue 3
priority high
shape percent 15
end
01-13-2008 12:18 PM
Can you post a show vlan for both sides and a show int trunk from both sides . Any reason why vlan 600 is missing on one side ? Check to see your native vlan matches on both sides , I think a show int switchport will give you that info .
01-21-2008 08:46 AM
Finally fixed the problem.
It was certainly obscure - one of the wide area links had suffered a partial failure. It was no longer handling traffic but staying live enough to keep the spanning-tree in check. As a result of this the routing was working through the other link but the latyer 2 traffic didn't fail over.
The link has now been repaired and is working as designed again.
Giles
