1310 disabled radio
Dec 31st, 2007
I have several 1310's at a site that the radios keep disabling and we have to reboot and enable the radio. Is is on IOS version c1310-k9w7-mx.124-3g.JA. Are there any known issues with this?
Shane
owillins Fri, 01/04/2008 - 09:44
May be the device is not negotiating with the inline power , so its happening .Verify that one.
redneckan Mon, 01/14/2008 - 07:47
The power supply is directly connected to the 1310, it is not POE. I had it checked on Friday and it has been running for 10 days, but once you try to get into it remotely it will not let you in. After rebooting it you can get in remotely. The radio did not go down though, just no remote communications. All data passed through it with out issues though.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
