layer 2 or layer 3 issue ? (diagram added)
Dec 31st, 2007
Hi everybody,
in order to connect a LAN to 02 redundant routers like the attached diagram, the question is when the port Gi0/1 in 2960 switch is active and Gi0/2 is blocked, all the 03 devices are reachable (respond to ping) and traffic goes through, but when port Gi0/1 is DOWN and the port Gi0/2 is active, the routers are not rechable from 2960 switch and no traffic is possible between switch and routers.
any suggestions ?
thanks.
tdanetsco Wed, 01/02/2008 - 08:42
happy new year !
i have configured HSRP between the two routers, but the problem is always the same,
any idea.
thanks.
Jon Marshall Wed, 01/02/2008 - 08:44
Can you post configs of 2 routers and the switch.
Also when you configured HSRP did you make the default-gateway on the switch point to the Virtual IP address you configured under HSRP ?
Jon
