redistribution command questions
Dec 31st, 2007
I have a basic understanding of redsribing routes with a command such as this
router ospf 1
redistribute eigrp 1
However, I do not understand the following scenario
router ospf 1
redistribute connected subnets
redistribute bgp 6XXX subnets
network area 1
why would you issue the redistribute connected subnet command?
In my sho ip route ...everything is either
direclty connected or being learned O E2
Overall Rating: 5 (1 ratings)
Edison Ortiz Mon, 12/31/2007 - 08:22
When routes are redistributed into OSPF, only routes that are not subnetted are redistributed if the subnets keyword is not specified.
For instance, if you are redistributing from EIGRP and it has,,, they will be redistributed without problems because they are class C networks with /24 subnets
However, if you had,,, none of those routes will be redistributed because they are class A networks with /24 subnets.
If you attempt to redistributed without the subnet keyword, you will receive this warning:
% Only classful networks will be redistributed
Edit: I re-read your questions one more time and now I see what you are really after.
In your case, you would want the redistribute connected subnet command if you want to announce other Layer3 links that your router has, that aren't part of the subnet. Those links will be brought into the OSPF database as O E2, and you can verify it with the show ip os data.
brooklynheight Mon, 12/31/2007 - 12:14
correct- there are more subnets listed when i do # sh ip ospf data
192.168.96, 93, 92 etc..
is this because of the "redistribute connected subnet" command?
If I am announcing these other subnets..
couldn't the "network 192.168.x.x" lines have been left out?..since they would have
been distributed anway with the "redistribute connected subnet" command?
Edison Ortiz Mon, 12/31/2007 - 12:26
If - 93.0/24 - 92.0/24 are directly connected links on this router, then yes, they were redistributed into OSPF by that command.
You need at least one network statement in order to enable OSPF on an interface and exchange routes with other OSPF routers. The redistribute command does not enable OSPF on an interface, it just announces the links to other OSPF speakers.
