InsufficientFreeMemory - NVRAM
Dec 31st, 2007
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 131072K 67510K 63562K 32768K 19086K 13682K 512K 491K 21K
2 262144K
Getting this error message in DFM.
1) How can you increase the size of the nvram?
2) What else is stored in NVRAM besides the startup-config?
3) What is the recommended free NVRAM for a CORE/6000 series/CATos switch?
Thanks.
PAUL TRIVINO Mon, 12/31/2007 - 10:57
  • Bronze, 100 points or more
1) I don't recall ever hearing of a way to increase NVRAM. You *could* use tftp configuration if the config is too big. (But to need that you'd need a massive config...)
2) There are a couple files kept there, but usually not big enough to affect what you're doing...
nancyrawls Thu, 01/03/2008 - 15:13
Not yet. Is there a command to see what files are actually stored in NVRAM?
Thanks.
MUHAMMAD SHAHEEN Thu, 01/03/2008 - 15:35
  • Silver, 250 points or more
on Cisco IOS switches the command is Switch#dir nvram:
it should list all files stored in NVRAM, you can also use Switch#dir flash: as an alternative of Switch#Show flash
I am sure on Cisco CatOs the commands are same and i cannot try them at this moment intime as I am not in the office.
Shaheen
nancyrawls Fri, 01/04/2008 - 12:04
This is CatOS so ...if that is the command to show the contents of nvram then what is the command to see the files stored on the pcmcia card?
Thanks alot!
dabels Fri, 01/04/2008 - 13:14
on the pcmcia slot depending on the type of card (could be a disk maybe) dir slot0: if it is a disk type of devices then dir disk0:
