CCENT task requirements
Dec 31st, 2007
Does anyone know the exact skill requirements for the practical part of the CCENT? I can log in, change port settings, load IOS and config files from TFTP servers, and a few other things. In other words, where does CCENT stop and CCNA start. I want to practice for the CCENT, take it, then move on to the CCNA.
Is there a list of all the testable task for this test?
Overall Rating: 4 (1 ratings)
LordFlasheart Tue, 01/08/2008 - 00:33
Having had a few crows sit the exam recently the most in-depth configuration you need to know for CCENT is RIP. There is a lot of theory to learn and it is wise to learn wireless inside-out too. If you buy the Odom CCENT/CCNA ICND1 Cisco Press book then it covers everything you need to know for the exam.
Please rate if helpful.
Chris
http://www.subnettingmadeeasy.blogspot.com
