877 ROMMON Recovery
Answered Question
Dec 31st, 2007
I am working with an 877 router trying to do a disaster recovery from a bad flash image and I am getting this error when I try and do the tftpdnld from rommon. I set the parameters for the download, but when I try to do it I get the following. Do I have to init the flash memory? or is this an indication of bad physical flash memory.
Configured in Router:
IP_ADDRESS=192.168.1.1
IP_SUBNET_MASK=255.255.255.0
DEFAULT_GATEWAY=192.168.1.3
TFTP_SERVER=192.168.1.3
TFTP_FILE=c870-advipservicesk9-mz.124-15.T1.bin
Error While uploading IOS :
rommon 9 > tftpdnld
IP_ADDRESS: 192.168.1.1
IP_SUBNET_MASK: 255.255.255.0
DEFAULT_GATEWAY: 192.168.1.3
TFTP_SERVER: 192.168.1.3
TFTP_FILE: c870-advipservicesk9-mz.124-15.T1.bin
Do you wish to continue? y/n: [n]: y
flashfs[0]: dir struct error[1].
flash: file system initialization failed
*** Machine Check Exception ***
PC = 0xfff19798, Vector = 0x200, SP = 0x80004bdc
monitor: command "tftpdnld" aborted due to exception
tftpdnld
,,,,,,,,,,,,,,,,,,,, [TIMED OUT]
TFTP: Operation terminated.
Correct Answer by Joe Clarke about 9 years 3 weeks ago
The dir struct error indicates bad flash. An RMA or other flash replacement is required.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 12/31/2007 - 10:57
