How do you ceate a custom ACL name on ASA through ASDM?
Dec 31st, 2007
When going thru the ASDM VPN wizard and defining source and dest hosts for access, it creates a generic ACL name like 'outisde_2_....'. I want to be able to name the ACL something that makes sense. How do I do that easily without having to make changes to the ACL at the command line once the wizard is finished?
JORGE RODRIGUEZ Mon, 12/31/2007 - 14:29
  • Green, 3000 points or more
sure you could do that but to be honest it is best to leave is as , the reason why is you already started with teh wizard and if you start changing the ACL names pertaining to Ipsec you will also need to carefully work with your crypto map outside_map statement as well in order to have the tunnel functioning properly, all this needs to be done through the cli, ASDM will not give you that option of picking an ACL name for when creating tunnels.. that is why is called wizard, it does everything for you, on the other hand if you want to be more specific with named ACLs then you need to start practicing cli.
Rgds
Jorge
