CM Administration problem-newbie question
Answered Question
Dec 31st, 2007
I'm terribly sorry for a silly question, but I have installed CUCM 6.01 under VMware and have created Administration username/password (I was aked to create one during the installation process). When I try that combination on CM Administration page, it gives me:
"Non defined IMS Exception".
Does anyone knows what seems to be a problem?
Many thanks in advance, Alex
Overall Rating: 5 (1 ratings)
ccbootcamp Tue, 01/01/2008 - 20:55
  • Gold, 750 points or more
It sounds like a Java error to me. Have you updated your java client?
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
stevana1969 Wed, 01/02/2008 - 07:19
Following your advice, I have updated to JRE 1.6.0.3, but the error still exists.
Regards, Alex
stevana1969 Fri, 01/04/2008 - 06:04
I started to wonder if I'm the only one receiving this message...
Cross my fingers :-)
stevana1969 Fri, 01/04/2008 - 09:25
Dear kmr,
Many thanks for your post, since it has solved my problem !!!!
Now I can proceed further, finally.
Regards, Alex
kmr Fri, 01/04/2008 - 09:28
Curious... which method worked for you, the CLI reset password or verification of LDAP params in CUCM?
stevana1969 Fri, 01/04/2008 - 09:34
Dear kmr,
I tried CLI only and it was enough:
(admin: utils reset_ui_administrator_password)
Afterwards, I was able to logon normally to CM Administration page.
Regards, Alex
