fropert Tue, 01/01/2008 - 09:46
Yes!
First, the IP audit feature. This one contains approximately 50 basic signatures on IP, ICMP, TCP flags, DNS, UNIX RPCs and fragmentation.
These sigs are classified into 2 families: Informational and Attacks.
You can define a policy on Informational sigs and another policy on Attacks sigs for each interface (policy-to-interface mappings).
The policy configuration considers 2 things:
- Does an alarm should be generated ?
- If the triggered packets will drop, reset or pass
Second, ASA now have a feature called "Threat Detection".
This feature detect DoS and scanning (nmap scans by example) attacks and give you statistics about threats.
Scanning IP source can be shuned.
Hope it will help you!
Francois
Jens Becker Sat, 01/12/2008 - 04:19
The Threat Detection feature comes with version 8.x. You can find it in ASDM under "Configuration" -> "Firewall" -> "Threat Detection"
or on the cli (example):
threat-detection basic-threat
threat-detection scanning-threat shun except object-group admin
threat-detection statistics
For configuring ip-audit first you must configure new IP-Audit policies.
