How do you delete site-to-site vpn from asa 5510
Jan 1st, 2008
I have setup site-to-site vpn(s) on ASA5510. I used a wrong remote IP addy and tried to edit or delete it from the ASDM IPsec Rules and Tunnel policy to no success. I end up creating another site-to-site vpn with right remote IP addy. Is it a way to delete remote side host/network from asa5510 box? I tried edit, delete and nothing works. Please advice.
Thx,
Eric
Overall Rating: 3.8 (4 ratings)
SteveDexter Tue, 01/01/2008 - 18:53
Connect to the ASA with telnet or ssh, do a show run and include the IP address of the remote host. And then do a no to the line.
srue Tue, 01/01/2008 - 19:14
clear configure crypto map 10
clear configure tunnel-group 10.1.1.1
*assumes '10' is the sequence number you want to get ride of, and that 10.1.1.1 is the wrong peer you have configured.
Eric Boadu Wed, 01/09/2008 - 11:51
Hello everyone,
Sorry for not responding. I was out for an emergency travel and just came back. Your config did the trick. I also removed them from the Global Objects on ASDM as well.
Thx,
Eric
ccbootcamp Tue, 01/01/2008 - 20:44
Can you post your config and the IP address you want to remove? I'll give the you exact commands to type.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
