Pix multiple issues
Jan 1st, 2008
Hi ,
I am runnnig 7.07 in pix 525 with the following problems :
1.Cpu utilzation is extermely high. (52%)
If I analyse the cpu profile will that incerase the utlization further?
2.My pixes have failed and crash thread is fover_serial_rx and it is showing block memory exhaustion both count and low is showing 0 in the crash .
Though there is a bug CSCsh32241 but it has been resolved in this code .
3.My config is very big so if I use turbo ACl how will it impact the performance .
Thnks in advance
rajbhatt Wed, 01/02/2008 - 23:18
Hi ,
Was just expecting if some one has any ideas on this
Fraser Reid Thu, 01/03/2008 - 02:07
TurboACL - do you have a large amount of ACL's in config - if yes then use turbo ACL 1 time to compile them - then it should run a little better (performance-wise)
CPU load - how much traffic is passing through the device ?
....just my thoughts on this
JORGE RODRIGUEZ Thu, 01/03/2008 - 06:14
I thought I saw similar thread a while ago on this issue, you may want to do a search in security forum on high cpu pix 7.0, I believe mention of getting out of 7.0 and alteast use 7.2 as this version is much more statble, check bug tool database pertaining 7.0.
cisco24x7 Thu, 01/03/2008 - 06:37
What do base this information on? How do
you determine that 7.2 is much more stable
than version 7.0.7?
Version 7.0.7 is more stable than version
7.2 because 7.0.7 is GD while 7.2 is ED
(Early Deployment).
CCIE Security
cisco24x7 Thu, 01/03/2008 - 10:45
How would you explain the fact that 7.0(7) is
GD while 7.2 is ED? I was informed by Cisco
TAC that GD is for General Deployment, means
that this is very stable code release. Early
Deployment, ED, means the code in its early
deployment phase and it is not as stable as
General Deployment.
Am I wrong about this?
Fraser Reid Thu, 01/03/2008 - 22:36
I am currently running 7.2 on all my PIX's without problems - so maybe a good idea to upgrade....
rajbhatt Fri, 01/04/2008 - 02:58
Thanks for ur replies
I would upgarde to 7.2.3 and see if anything good actaully comes from it.
But it does have some bugs realted to 7.2.3 : memory problem
and crash is due to block memory exhaution .
Any ideas on cpu profile activates ?
how does that impact cpu utilization
rajbhatt Thu, 01/10/2008 - 22:31
HI ,
Could any one throw any light on this :HIgh cpu on pix
for sh process : I have an unusual reading on arp and dispatach unit .
PC SP STATE Runtime SBASE Stack Process
Lwe 00105f05 01191fa0 00ea5be0 0 01190018 8072/8192 block_diag
Mrd 0020d172 0177d140 00ea5c80 113745167 017751f8 27976/32768 Dispatch Unit
M* 0073955b 0009feec 00ea5c80 1095 0638a5b0 25180/32768 accept/http
Mwe 00a73a19 0447fa38 00ea5b98 13 0447dac0 5740/8192 ssh/timer
- - - - 798544616 - - scheduler
- - - - 922889167 - - total elapsed
Here is sh blocks
Result of the command: "sh blocks"
4 300 295 299
80 116 0 116
256 3636 3476 3636
Here is also an out put fron sh traffic ?
Do i need to upgarde the interfaces
