L2VPN Interworking Problem
Jan 2nd, 2008
There is a scenario:
(CE1)7600-----FE VLAN(dot1q)-----(PE1)7200VXR(NPE300)----FE----(PE2)7200VXR(NPE400)----atm----(ATM cloud)------frame relay------(CE2)2811
I want to bridge traffic between Ethernet interface to ATM interface on PE Router Cisco7200 with L2VPN Interworking.I used the IP mode interworking, VC is UP, I'm trying to ping from 7600 to 2811,it can't work.I want to know why? if you have any other suggestion to make the L2VPN Interworking configuration on 7600 to 2811 , please advise.
Thanks in advance
