troubleshoot for login to the router
Jan 2nd, 2008
Could anyone pls help me for the following issue ?
After this , iam unable to get enter into the router.
We are able to ping the router.
We even did the reload of the router , still problem persist the same.
Trying 192.239.131.147...
Connected to 192.239.131.147.
Escape character is '^]'.
Richard Burts Wed, 01/02/2008 - 04:08
vidyaprakash
If you are having problems with telnet access, are you still able to access the router via its console? If so are there any error messages in the logs of the router?
Is it possible that the vty lines were configured with "no exec"? I believe that configuring no exec on the vty lines would produce symptoms like this. I have seen situations where someone configured no exec in the assumption that it was an abbreviation for no exec-timeout. Unfortunately no exec is a separate command and disables starting an exec session on the line. If the vty lines are configured with no exec, try configuring exec on the vty lines and let us know if this fixes the problem.
Rick
vidyaprakash Wed, 01/02/2008 - 04:20
Hi Rick,
Many thanks for the immediate response.
I dont any access via console to look this issue.
Issue started , when this vpn is renamed from VPNA to VPNB.(i.e. PE to CE)
When it was in VPNA , we were able to telnet the router.
Currently iam engaging the engineer for this issue to arrange field support.
I will update the same once this issue is fixed
PRakash
