Nokia E61 Cisco client
Jan 2nd, 2008
Hey
is there a way to add some dialling rules so that when the phone is on WIFI it will automatically prefix the dialled number with 0 ( or whatever the button is for external line in the CME )?
Currently I have to dial one way when I m on GSM and another way when I am on WIFI and it means I cannot transparently use the features as I want, i,e it is to easy to forget to dial leading 0 once on WIFI.
Any hints much appreciated.
Jasper van Nederpelt Tue, 02/19/2008 - 23:27
Hi there,
Has anyone found a solution for this yet?
We are dealing with the same problem.
Thanks for your reply.
Gr,
Jasper
douhanm Wed, 02/20/2008 - 22:12
Yes it was quite easy actually, just add a dial-peer with a COS that makes your intellisynch only see this dial-peer and have it automatically prefix the 0 and then it just works.
above is for ucme if you use ucm you can achieve the same with search spaces etc.
