Chris Deren Wed, 01/02/2008 - 06:35
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Can you post your GW configuration?
Are you playing MOH from flash or is it multicast traffic to the remote location?
If from flash make sure you have loopback ip address referenced in the "mulicast moh" command.
Chris
Chris Deren Wed, 01/02/2008 - 07:14
  • Hall of Fame,
Your configuration looks OK, here are some tips that have worked for me in the past:
remove both moh commands under fallback and add them again
if that does not work try:
remove and re-add "ccm-manager music-on-hold"
reboot the router
Chris
