frequest re-associations
Jan 2nd, 2008
Users at one of my autonomous based sites are frequently being kicked off wireless.
I have a user who is sitting in one place close to a WAP. For some reasoning he is moving between 3 WAPs.
all waps have the following version of code;
Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(8)JEA3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 21-Nov-07 13:56 by ccai
ROM: Bootstrap program is C1200 boot loader
BOOTLDR: C1200 Boot Loader (C1200-BOOT-M) Version 12.3(2)JA4, RELEASE SOFTWARE (fc1)
scottmac Wed, 01/02/2008 - 14:36
  • Green, 3000 points or more
As a first stab here, I'd guess they're using Intel NICs or chipsets in their systems.
If that's true, have them update to teh latest drivers, available from Intel's site, or the manufacturer's site.
If it's an older Intel NIC/chipset and drivers, and you're running TKIP, you might see some MIC errors and the whole radio is shutting down for short periods.
This is normal; two MIC errors, by spec should drop the radio briefly: It thinks it's under attack .. this feature can be configured off.
IF the drivers are fairly recent, try setting the "Roaming Threshold" higher. This is also a NIC setting under the 'Advanced" tab, I think.
If that doesn't help, re-position your antennas, the humans can be getting in the way of the signal.
Also, perhaps, bring up NetStumbler and check for signal and noise levels for the channel in-use. Maybe try another channel (1, 6, and 11 only, go for the least used).
The un-moving roam is usually just old Intel drivers ... so update first, then chase signals and noise.
Good Luck
Scott
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
