VPN Client Stuck on Contacting Security Gateway
Jan 2nd, 2008
When trying to establish a VPN connection through my home wireless router (Trendnet TEW-431BRP)after I enter my authentication information, the client stays on "Contacting Security Gateway". I'm not using a firewall on the router. Any other connection, i.e. dialup, works fine.
johnd2310 Wed, 01/02/2008 - 14:52
Sometimes the vpn client has problems with wireless connections. Try dropping the mtu on the vpn client using the set mtu utility.
John
